查看: 407|回复: 2
壁挂式取暖器一定要装机械断开开关吗?
发表于 2012-1-10 18:53:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一取暖器,带遥控的,壁挂式,带遥控器,通过插头连接电源,
类似于空调市内机,
这种取暖器一定要装机械开关吗?
相关条款如下:
IEC 60335-2-30取暖器标准
22.109 The disconnection of the supply by a switch in the off position shall not rely on
electronic components.
IEC 60335-1中对off position的定义:
off position
stable position of a switching device in which the circuit controlled by the switch is
disconnected from its supply or, for electronic disconnection, the circuit is de-energized
NOTE The off position does not imply an all-pole disconnection.
发表于 2012-1-10 18:53:50 | 只看该作者
意思是不要装一个实质上只是控制电子线路动作的开关。它会使人误会成器具已与电源断开了(不一定需要是全极断开)。这种误会是危险的,因为人们很可能出于防尘需要而将其覆盖。
发表于 2012-1-10 18:54:01 | 只看该作者
电暖器都要装机械断开总开关
GMT+8, 2026-10-18 17:46 , Processed in 0.065685 second(s), 18 queries , Gzip On.
