查看: 391|回复: 6
Pump for swimming pool standard 是60335 2-41 吗?
发表于 2012-1-9 22:52:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发表于 2012-1-9 22:54:35 | 只看该作者
是的,你们的产品应该是水池过滤器吧
发表于 2012-1-9 22:56:09 | 只看该作者
May be not.
in IEC 60335-2-41
6 Classification
This clause of Part 1 is applicable except as follows.
6.1 Modification:
Submersible pumps for use in swimming pools, when persons are in the pool, shall be
class III with a rated voltage not exceeding 12 V.
Other submersible pumps for use in water and other conducting liquids shall be class I or
class III. However, aquarium pumps may be class II.
Portable pumps for cleaning and other maintenance of swimming pools shall be class I or
class III.
Other pumps shall be class I, class II or class III.
发表于 2012-1-9 22:57:09 | 只看该作者
不错,emperorlee 真是有心了
发表于 2012-1-9 22:57:55 | 只看该作者
谢谢,不过都是现学现卖的,我是菜鸟,赚金币来的。
 楼主| 发表于 2012-1-9 22:58:56 | 只看该作者
是水池过滤器 呀,不是Submersible pumps,有一个进水口,一个出水口,应该是60335 2-41 吧
发表于 2012-1-9 23:00:14 | 只看该作者
for swimming??水池过滤器??如果是用在游泳池内,也不适用60335 2-41,因为有人在游泳池里。以人为本哦,而且你的东西不是用在水里吗?
GMT+8, 2026-10-18 17:19 , Processed in 0.027849 second(s), 18 queries , Gzip On.
