查看: 548|回复: 1
关于各种插头的接地电阻值的问题
发表于 2012-1-9 21:51:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
小弟今天偶然发现一款南非大三元插头的电源线(总长1.8M)接地电阻竟然高达420m欧,所以在此想请教各位高手,各种电源插头的接地电阻有没有标准要求,分别是多少?标准规定的接地电阻不大于100m欧,这100的值包不包括器具外露的电源线及插头的阻值,请大家解惑,谢谢!
发表于 2012-1-9 21:52:41 | 只看该作者
就IEC60950-2005 而言,有如下定义:
1.2.13.11
PROTECTIVE BONDING CONDUCTOR
conductor in the equipment, or a combination of conductive parts in the equipment,
connecting a main protective earthing terminal to a part of the equipment that is required to
be earthed for safety purposes
判定条件:
The resistance of the PROTECTIVE BONDING CONDUCTOR, calculated from the voltage drop,
shall not exceed 0,1 : . After the test, the PROTECTIVE BONDING CONDUCTOR shall not be
damaged.
由以上可以看出,是不包括电源线的。
GMT+8, 2026-10-18 17:32 , Processed in 0.065733 second(s), 19 queries , Gzip On.
