查看: 445|回复: 4
潮湿后的积水怎么处理
发表于 2012-1-8 17:09:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个问题困惑我很久了,要是不把积水搞掉,电气强度和泄漏电流很容易出问题,可是我又没见到过哪个标准说要怎么去处理积水的问题,请大家赐教!
发表于 2012-1-8 17:09:22 | 只看该作者
千万别做任何处理,有这积水,就是为了引出电器强度和泄漏电流的问题
发表于 2012-1-8 17:09:29 | 只看该作者
Although I am not so clear about your question, but my suggestion is:
1. Firstly you must be clear that which kind of pollution degree your products are covered. for example if pollution degree 3, then the condensation is normal, so under this case, you must let the clearance and the creepage distance big enough to fulfill the requirements of the related products, as well these distances are also related with the materials' characteristics...
2. Secondly, if you are already clear the pollution degree of your products, and you also know that the current spacings of your products can not fulfill the requirements of the related standards, then at this time, you also can reference your products' standard, and I think there must be some descriptions about how to compromise the requirements of the spacings, such as coating on the PCB and add some enclosures, or something like this, so read it carefully, then you'll know how to deal with it..
3. Finally, make a conclusion, at the total begining of the design, there must be a clear defination about your products, such as which pollution degree, IP class, overvoltage category and etc, then the designers can have an outline to correctly design the products, so as safety engineer, you must know the standards better than others, then you can give and show the instructions to the related guys...
 楼主| 发表于 2012-1-8 17:09:37 | 只看该作者
虽然我英文不是很好,但我还是知道你说的要跟我说的问题一点关系也没有...
发表于 2012-1-8 17:09:43 | 只看该作者
I‘m so sorry for not helping you...
GMT+8, 2026-10-18 17:19 , Processed in 0.027719 second(s), 18 queries , Gzip On.
