查看: 507|回复: 3
GS电吹风做降压测试时电机要分离吗?
发表于 2012-1-8 16:21:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
19.101 Replace the complete text of this subclause by the following:
Hairdryers are operated as specified in Clause 11 until steady conditions are established. The
voltage at the terminals of the motor is then reduced until the running speed of the motor is
just sufficient to prevent the thermal cut-out from operating, the power input to the heating
element being maintained at 1,15 times rated power input.
The voltage is decreased at
– 1 V per minute, for motors having a working voltage not exceeding 30 V;
– 5 V per minute, for motors having a working voltage exceeding 30 V.
The appliance is then operated until steady conditions are established.
好像上面没提到电机要分离,大家做过GS认证的说下
发表于 2012-1-8 16:21:39 | 只看该作者
单独对电机供以工作电压,发热元件上的电压保持在11.4试验所用数值。以5%的数值减小供给电机的电压,持续5分中,重复直到找到热断路器断开时候的电压,在上调5%,就为电机工作的电压。
发表于 2012-1-8 16:21:48 | 只看该作者
the power input to the heating element being maintained at 1,15 times rated power input.
注意这段 这个应该是说明的很清楚了
发表于 2012-1-8 16:21:56 | 只看该作者
EN60335-2-23/A1:2008对19.101作了修改,09年2月1日开始实施的。
GMT+8, 2026-10-18 17:05 , Processed in 0.033873 second(s), 19 queries , Gzip On.
