查看: 391|回复: 0
求助(IEC 60335-1 19章电子失效的实际操作方法)
发表于 2012-1-7 23:37:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如何对MOS 做IEC 60335-1 A2 cl 19.11.2 g)的测试?
节示标准如下:
19.11.2 g) failure of an electronic power switching device in a partial turn-on mode with loss of gate (base) control. During this test, winding temperatures shall no exceed the values give in 19.7.
NOTE 3 This mode may be simulated by disconnecting the electronic power switching device gate (base) terminal and connecting an external adjustable power supply between the gate (base ) terminal and the source (emitter) terminal of the electronic power switching device. The power supply is then varied so as to achieve a current that will not damage the electronic power switching device but give the most onerous conditions of test.
标准的意思:
将MOS管的栅级断开再外加电源为MOS管供电,目的是要模拟出既要MOS不烧坏又要出现发热的最严酷的情况。标准上只是说了个原则上是:既要MOS不烧坏又要出现发热的最严酷的情况.
但是实际操作比较困难!
那位大佬有没有比较好的办法分享一下?谢谢!
GMT+8, 2026-10-18 17:19 , Processed in 0.027823 second(s), 18 queries , Gzip On.
