查看: 433|回复: 1
UL1083里的非正常测试
发表于 2012-1-7 20:48:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
对于带外接电源线棒的温控煎锅老说 温控需不需要短路 具体怎么操作的 标准我看了一下不太明白
发表于 2012-1-7 20:48:46 | 只看该作者
应该进行UL 1083 46.4的“ABNORMAL OPERATION TEST - SKILLET”测试,方法还是比较简单的,关于电压的选择,样品的放置相信楼主应该都看的明白,简单说下具体的做法:
Part 1 - The unit was operated with 1/2 in. (12.7mm) of fresh unused pure cold pressed peanut oil with the thermostat set to the position that gave maximum heat and with the appliance initially at room temperature. It was operated for a period of 7-1/2 hours, or until ultimate results were observed. The cover was not in place.温控器设置到产生最大温度的位置(根据前面的正常温升测试),锅内添加12.7mm厚的新鲜未使用的压榨花生油,电压是额定电压或额定功率下的电压取大值,从室温开始测试,直到运行7.5小时或最终结果产生。锅盖敞开。
Part 2 - Part 1 was repeated except with the oil drained from the appliance and leaving a residual film of oil behind.
重复上面的测试,但锅内只残留一层油膜就可以(类似于干烧,只是锅上残留一点油膜——把油倾倒后自然留下的油)
结果判断是:1、泄露电流是否超;2、3A fuse是否断开;3、器具的支撑外壳塑料是否发光、发热,金属件是否融化变形;4、未经保护的带电部件是否裸露
GMT+8, 2026-10-18 17:19 , Processed in 0.029443 second(s), 18 queries , Gzip On.
