查看: 360|回复: 1
关于IEC 60335-2-30 11.2
发表于 2012-1-7 17:56:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
11.2描述 ---便携式加热器要使其后背离某一边壁150mm并远离其它边壁;
----其他通常放置在地板上使用的加热器要使其后背尽可能紧靠某一边壁并远离其它边壁。
但是,以几个方向散发热量的圆形和类似加热器要放置到远离某一边壁300mm并远离其它边壁;
如果一个电暖器符合便携式加热器和放在地板上使用的加热器
是不是两个条件都要测试还是按最残酷的做测试?
这两种情况通常都在一种电暖器
我认为是两种都要做,你们觉得呢?
发表于 2012-1-7 17:56:24 | 只看该作者
是便携式风扇式加热器才与测试角有150mm的.其它的要尽量靠在测试角边壁.
11.2 Replacement: Heaters normally placed on the floor are placed in a test corner as follows:
– portable fan heaters are placed with the back 150 mm from one of the walls and away from the other wall;
– other heaters are placed on the floor with their back as near to one of the walls as possible and away from the other wall. However, circular and similar heaters that emit heat in several directions are placed 300 mm from one of the walls and away from the other wall. Heaters containing PTC heating elements are placed away from the walls if this results in higher temperatures.
GMT+8, 2026-10-18 16:38 , Processed in 0.062522 second(s), 19 queries , Gzip On.
