查看: 391|回复: 2
EU test 普通果汁机
发表于 2012-1-7 17:54:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
产品是普通果汁机。以下是客人的回复,意思不明白,请帮忙解释一下,谢谢!
How are you? I am so sorry to inform you that. Regarding the EU test result:
Model# YTT-906A, test result is 5 / 10. It doesn’t work well in the testing. Because, The product can’t crush ice. If the EU put any speed, the machine can ‘t crush. If it put pulse, it will leave big pieces and it is not acceptable. Also the carrot test: the waste is 79 gr. where we have to have less than 10 gr. Now, please advise you will improve to the blade.
Model# YTT-906B, test result is 0/10.Same case of the model#906A. The product can’t crush ice. If the EU put any speed, the machine can ‘t crush. If it put pulse, it will leave big pieces and it is not acceptable. Also the carrot test: the waste is 79 gr. where we have to have less than 10 gr. Now, please advise you will improve to the blade.
发表于 2012-1-7 17:55:02 | 只看该作者
客人在抱怨搅拌机不能碎冰,打胡萝卜的残渣太多,要求改进刀具。
发表于 2012-1-7 17:55:12 | 只看该作者
提醒一下,虽然客户是这么说,但也有可能不是刀具的原因喔
GMT+8, 2026-10-18 16:38 , Processed in 0.063521 second(s), 18 queries , Gzip On.
