查看: 372|回复: 7
foot massage loading
发表于 2012-1-6 19:17:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
"Appliance having a liquid container are filled with water in accordance with the instruction and loaded with a mass of 10kg" the text from the Clause 3.1.9 of IEC60335-2-32 . I think "a mass of 10kg" contain the water . but I can not confirm .
发表于 2012-1-6 19:18:00 | 只看该作者
10Kg的重量应该是附加的,不包含水的重量
发表于 2012-1-6 19:18:07 | 只看该作者
The first floor, I can't agree more...
 楼主| 发表于 2012-1-6 19:18:14 | 只看该作者
please give a reason or resource.
thanks
发表于 2012-1-6 19:18:21 | 只看该作者
It is clear that the container "are filled with water in accordance with the instruction and loaded with a mass of 10kg"
即:容器按说明注水+10kg负载
发表于 2012-1-6 19:18:28 | 只看该作者
"a mass of 10kg" didn't contain the water
 楼主| 发表于 2012-1-6 19:18:35 | 只看该作者
thsnks very much
the answer that provided by caballo3157 .read and understand the standard must be very careful.
 楼主| 发表于 2012-1-6 19:18:42 | 只看该作者
a new question:
a foot massage is opertaed with the cantain filled with water accorded to the MAX level. The function was contained: vibration+heating+blowing+infrared lens; but the heating function is provided by heating wire and the power is far from less than motor power. I read the GS report from the NEMKO laboratory,they marked that the appliance was heating appliance . But I think the appliance is moter-operated appliance or combined appliance. which opinion is suitable ?
GMT+8, 2026-10-18 16:25 , Processed in 0.028921 second(s), 18 queries , Gzip On.
