查看: 445|回复: 3
谁能发一个电吹风的GS测试规范标准
发表于 2012-1-6 18:35:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
谁能发一个按GS标准整理出来的电吹风测试规范,不胜感激。
发表于 2012-1-6 18:35:10 | 只看该作者
The test item for the hairdryer as below:
8 (8.1,8.2 except for 8.1.4) Accesses to live part
10 Power input and current test
11 Normal heating test
11.101 Heating test for swivel connection
13 Leakage current and electric strength test (in normal heating condition)
15.3/16.2/16.3 Humidity test/ Leakage current /electric strength test
19.2 0,85 times rated power
19.3 1,24 times rated power
19.101 Abnormal heating test
19.102 Abnormal heating test
21.1 Mechanical strength of enclosure
21.101 Drop test
22.5 VOLTAGE DISCHARGE TEST
22.12 Pull test for switch knob
22.24 Heating elements shall be supported by a effective means
23.5 Electric strength test for insulation of internal wiring
24.6 (Annex I) Motor having basic insulation that is inadequate for the rated voltage of the appliance
25.7, 25.8 Power cord should be used
25.14 Flexing test of supply cord
25.15 Cord anchorage test
29.1/29.2/29.3.1 Clearance/ creepage distance/ solid insulation (for live part of heating element and accessible surface)
30.1 Ball Pressure Test
30.2.1-3 Glow-Wire test
发表于 2012-1-6 18:35:18 | 只看该作者
请问longclever 有没有完整的?
发表于 2012-1-6 18:35:25 | 只看该作者
有一份完整的. 不过不知道怎么发上来,根据上面的测试项目,一般都可以找得到测试的方法在iec60335里面.值得注意的是如果是带swivel connector结构的话,是不需要做180度的cord flexing 测试的. 而要做20000次的swivel endurance 测试(clause 11.101). 在1500转的时候测量转尾的温度即可.
GMT+8, 2026-10-18 16:12 , Processed in 0.026956 second(s), 19 queries , Gzip On.
