查看: 369|回复: 1
求助干衣机负载布的制作
发表于 2012-1-5 20:31:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我参考了IEC61121和GBT20292关于干衣机的负载布的要求,上面只有需要床单和枕头套及毛巾多少个和其成品的尺寸,但并没有提到它们是单层还是双层。及其缝制的具体细节。请教有谁帮我查下相关的要求啊?或者说是和洗衣机的负载布做法类似吗,洗衣机是怎么做的。谢谢了!
发表于 2012-1-5 20:31:39 | 只看该作者
为什么用IEC61121,个人觉得是不是该用EN 60335-2-43:2003
Household and similar electrical appliances — Safety — Part 2-43: Particular
requirements for clothes dryers and towel rails;
这里面有对布的尺寸大小要求。
3.1.9中这样要求
Textiles positioned over the racks or rails in accordance with the instructions. The textiles
are pre-washed, double-hemmed cotton sheets having dimensions approximately
700 mm x 700 mm
and a specific mass between 140 g/m² and 175 g/m² in the dry
condition.
Four layers of textiles are used for appliances having a heated surface supporting the
textiles.One layer is used for appliances in which the textiles are dried by a warm airflow.
LZ看看是否适合这个标准!
GMT+8, 2026-10-18 16:12 , Processed in 0.026863 second(s), 19 queries , Gzip On.
