查看: 490|回复: 1
IEC60335-2-40 第19.7章节的疑问
发表于 2012-1-4 21:13:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如图,如题,请各位指点下哦。。。
具体怎么去理解,怎么去做这个测试的?
发表于 2012-1-4 21:14:02 | 只看该作者
in whole 19. chapter
you will do abnormal operations and you will see if there is something wrong etc.
so according to chapter 19.7. you will do the things the chapter says and you will check if the temperature rise is accaptable, if the device continues to withstand electrical strenght, if appliance melts, if appliance emits dangerous gases
GMT+8, 2026-10-18 15:34 , Processed in 0.031323 second(s), 18 queries , Gzip On.
