查看: 435|回复: 5
UL热风枪稳定性测试疑问
发表于 2012-1-4 19:11:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
UL499 CL8 Stability
8 Stability
8.1 The stability of a heating appliance shall be such that it will not be overturned readily during use.
8.2 A portable household heating appliance in which liquid is heated to a temperature greater than 115°F(46°C) is to be placed on a plane inclined at an angle of 15 degrees to the horizontal. The product is to be positioned and loaded with whatever combination of separable components, liquid, or other media(material) that results in the maximum tendency to overturn under conditions of intended use. The product is to contain at least 5 oz (148 mL) of liquid. The product is to be prevented from sliding on the inclined surface. The product shall not overturn as a result of this test
8.1说在正常使用过程中,发热器具应该不易翻倒
8.2 说可以装液体的器具
这样看来热风枪,还要做稳定性测试吗??
发表于 2012-1-4 19:11:21 | 只看该作者
要做的.
 楼主| 发表于 2012-1-4 19:11:28 | 只看该作者
热风枪的加拿大标准是什么??
 楼主| 发表于 2012-1-4 19:11:36 | 只看该作者
要做的.
做几度呢??
 楼主| 发表于 2012-1-4 19:11:43 | 只看该作者
热风枪,UL
用哪个标准??
要不要做稳定性测试??
发表于 2012-1-4 19:11:51 | 只看该作者
热风枪是手持式的器具吧,不需要做稳定性的吧
GMT+8, 2026-10-18 15:12 , Processed in 0.165737 second(s), 19 queries , Gzip On.
