查看: 363|回复: 5
如何规避灼热丝测试?
发表于 2012-1-4 19:10:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
IEC60335-1,
30.2.3 Appliances that are operated while unattended are tested as specified in 30.2.3.1 and
30.2.3.2. However, the tests are not applicable to
– parts supporting welded connections;
– parts supporting connections in low-power circuits described in 19.11.1;
– soldered connections on printed circuit boards;
– connections on small components that are mounted on printed circuit boards;
– parts within 3 mm of any of these connections.
NOTE Examples of small components are diodes, transistors, resistors, inductors, integrated circuits and capacitors not directly connected to the supply mains.
支撑焊接的连接 能不能给我一个实例?? 让我更好的理解
是不是说塑胶壳碰到了PCB上的焊点,也不需要做灼热丝测试??
离拔插端子距离小于3MM,需要做灼热丝吗??
发表于 2012-1-4 19:10:20 | 只看该作者
需要做,只是做550就可以,
发表于 2012-1-4 19:10:26 | 只看该作者
远离足够距离就可避开.
发表于 2012-1-4 19:10:37 | 只看该作者
这个是指碰焊,不是普通的焊接
 楼主| 发表于 2012-1-4 19:10:53 | 只看该作者
这个如何理解呢??
发表于 2012-1-4 19:11:01 | 只看该作者
如果你的塑胶壳不是用来支撑带电部件的,只要做550度就行了,如果是用来支撑带电部件的,就要做750度了.
GMT+8, 2026-10-18 15:12 , Processed in 0.047164 second(s), 18 queries , Gzip On.
