查看: 677|回复: 4
UL标签
发表于 2012-1-3 15:33:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我们公司是生产电机的,罩极电机,大定子上要上一层防锈油,所以一般的铭牌是粘性不够,耐温也要180度左右。以前用的是PET材料的不干胶,夏天的时候粘粘还是可以的,现在天冷了粘不住,就改用了胶是3M的上面那层还是PET材料,不知这样附不附合UL的标准。急急
发表于 2012-1-3 15:34:00 | 只看该作者
只看你们公司当初有没有报备具体材料,如有报备是PET的,不好改的。
发表于 2012-1-3 15:34:09 | 只看该作者
应该可以的
发表于 2012-1-3 15:34:19 | 只看该作者
Check your UL follow up procedure, find out the description about the marking requirements.
If the description only says UL PGDQ2/PGJI2 is required and there is no requirement related with the manufacturer, just the label provider, then I think it's ok, but make sure that the 3M label is UL approved;
If your procedure indicates the manufacturer's name, then it's will not be ok, try to deliver this information to UL engineer, and make an additional evaluation about this change.
Finally, don't ship out this kind of products with the label changed until this change is evaluated and accepted by UL....
发表于 2012-1-3 15:34:33 | 只看该作者
应该能改的
GMT+8, 2026-11-12 12:04 , Processed in 0.046098 second(s), 18 queries , Gzip On.
