查看: 630|回复: 2
CB说明书要求
发表于 2012-1-3 15:26:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教各位大侠,在CB认证中对说明书有什么要求?
因为我们的客人要求修改说明书尺寸,我担心减少尺寸之后字体看不清,这个有要求吗?
发表于 2012-1-3 15:26:58 | 只看该作者
Sufficient information shall be provided to the USER concerning any condition necessary to
ensure that, when used as prescribed by the manufacturer, the equipment is unlikely
to present a hazard within the meaning of this standard.
IEC标准里没提到对字体的要求。但UL标准里对字体的要求,见下:
²IMPORTANT SAFETY INSTRUCTIONS² and ²SAVE THESE INSTRUCTIONS²–
shall be entirely in upper case letters not less than 3/16 in (4.8 mm) high or emphasized to distinguish
them from the rest of the text. Upper case letters in the instructions shall not be less than 5/64 in (2.0 mm)
high, and lower case letters shall not be less than 1/16 in (1.6 mm) high.
 楼主| 发表于 2012-1-3 15:27:09 | 只看该作者
非常感谢你!
GMT+8, 2026-11-12 13:10 , Processed in 0.028738 second(s), 18 queries , Gzip On.
