查看: 404|回复: 2
关于钟机(clock radio)碰到的UL问题
发表于 2012-1-3 12:38:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大哥:
我们有一款钟机.已做货.现给UL新报备一家变压器.UL提出功率大于15W 如下:
The following inform ation is required to complete the investigation.
According to the report of Transformer, Model W41P-A0177 under File E333593,
the power measured was greater than 15 W, it cannot be used on the Radio-
Clock, Model RP5605-A which is employed with the HB Enclosure material. Also,
the thermal fuse employed on Transformer, Model W41P-A0177 was Type RH
125 which is not identical as the report under Transformer. Please double check
请问这个是什么意思.我们该怎么解决?
我们这款钟机标的额定功率是 120V 60Hz 13W
本人是刚接触音视频产品.请各位多指教!谢谢!
发表于 2012-1-3 12:38:21 | 只看该作者
让供应商提供小于15W的变压器就完啦.
如果大于15W,塑胶料用HB就不行了.
后面好象是说,供应商变压器内的保险RH125同原来的做认证时不一样.
 楼主| 发表于 2012-1-3 12:38:30 | 只看该作者
谢谢!
1 请教15W是怎么测试来的?
2 变压器的保险丝供应商确实用错了
GMT+8, 2026-10-18 15:12 , Processed in 0.069508 second(s), 18 queries , Gzip On.
