查看: 535|回复: 5
电磁炉电磁线圈灼热丝问题
发表于 2011-12-31 16:20:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
现在有一款电磁炉产品,他的电磁线圈托盘做750灼热丝不过。我同事都说因为托盘上没有导线连接,所以不用做的,但我又再之前的一份CB报告上看到有做过750的例子,现在脑子很乱啊,有人能帮我解答一下吗?谢谢啊
发表于 2011-12-31 16:20:15 | 只看该作者
你的线盘绕组有没有与托盘接触?如果有接触需做750度灼热丝.见如下标准.
30.2.2 For appliances that are operated while attended, parts of non-metallic material supporting current-carrying connections, and parts of non-metallic material within a distance of 3 mm of such connections, are subjected to the glow-wire test of IEC 60695-2-11. However, the glow-wire test is not carried out on parts of material classified as having a glow-wire flammability index according to IEC 60695-2-12 of at least
– 750 °C, for connections which carry a current exceeding 0,5 A during normal operation,
– 650 °C, for other connections. If the glow-wire flammability index is not available for a sample with a thickness within
发表于 2011-12-31 16:20:27 | 只看该作者
一般的线圈都是与托盘接触的,我们也是做750
 楼主| 发表于 2011-12-31 16:20:43 | 只看该作者
主要现在我同事认为线圈是一整根绕在托盘上的,并没有与托盘进行电气接触,所以就认为不需要做测试,是否正确呢?
发表于 2011-12-31 16:20:57 | 只看该作者
这个需要做测试的,你的线圈和托盘是有接触的。
发表于 2011-12-31 16:21:10 | 只看该作者
托盘只要与线圈接触,或者与线圈的距离小于3mm,就必须进行750度灼热丝测试
GMT+8, 2026-10-18 15:07 , Processed in 0.104779 second(s), 18 queries , Gzip On.
