查看: 418|回复: 2
对于家用电器可拆卸部件,安规上要求用多大的力拆卸是合适的
发表于 2011-12-31 16:04:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请老师指点,对于家用电器可拆卸部件,安规上要求用多大的力拆卸是合适的?
发表于 2011-12-31 16:05:09 | 只看该作者
detachable part
part that can be removed without the aid of a tool, a part that is removed in accordance with
the instructions for use, even if a tool is needed for removal, or a part that does not fulfil the
test of 22.11
NOTE 1 If for installation purposes a part has to be removed, this part is not considered to be detachable even if
the instructions state that it is to be removed.
NOTE 2 Components that can be removed without the aid of a tool are considered to be detachable parts.
NOTE 3 A part that can be opened is considered to be a part that can be removed.
可拆缷部件,没有力量限制。
发表于 2011-12-31 16:05:24 | 只看该作者
虽然对于可拆卸部件没有力量限制,但是如果你一定要考虑一下,你可以参照条款22.11,因为如果满足22.11的零件可以被当作不可拆卸部件。
GMT+8, 2026-10-18 15:07 , Processed in 0.028496 second(s), 18 queries , Gzip On.
