查看: 448|回复: 1
IEC 60335-2-14 Cl. 20.103
发表于 2011-12-27 12:30:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
20.103 Hand-held blenders shall incorporate a biased-off switch, its actuating member being
positioned in a recess or otherwise guarded to prevent accidental operation.
NOTE This requirement does not apply to hand-held food mixers provided with a blender attachment.
Compliance is checked by applying a cylindrical rod, having a diameter of 40 mm and a
hemispherical end, to the switch. The appliance shall not operate.
这是标准的原文,我想问下,biased-off switch 是指什么类型的?如果一个产品,他的开关必须要用一个手一直按住才能工作,那为了符合此款标准,这样的开关需要满足什么要求?
发表于 2011-12-27 12:30:30 | 只看该作者
简单说biased-off switch就是按着的时候才是On的开关,松开就自动断开电路。这个标准条款就是要使用 一个biased-off switch,而且使用一个40mm的半球测试探棒不能触发开关。。。
GMT+8, 2026-10-18 14:12 , Processed in 0.029634 second(s), 19 queries , Gzip On.
