查看: 714|回复: 4
关于家用电器内,电子线路设计,熔断丝的参数选择问题
发表于 2011-12-27 11:47:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
安规的工作,我个人觉得,更重要的是利用自己对于安规的理解,实际贯彻到产品的设计过程中去。此贴是我之前做到一个分析报告。用于设计工程师的培训。但是,感觉还是有很多遗漏,例如关于快速熔断和慢熔断,延时熔断到选择依据等等。发上来供大家完善评阅。
如下为引用标准GB4706.1—1998的内容,当熔断器的设置,是为了当模拟电子线路非正常测试时起保护作用的情况,熔断器应当按照如下进行考核,判断的条件为 “电路被充分保护”
If the safety of the appliance under any of the fault conditions depends on the operation of a
miniature fuse-link complying with IEC 60127, the test of 19.12 is carried out.
19.12 If safety of the appliance depends upon the operation of a miniature fuse-link
complying with IEC 60127 during any of the fault conditions specified in 19.11.2, the test is
repeated but with the miniature fuse-link replaced by an ammeter. If the current measured
– does not exceed 2,1 times the rated current of the fuse-link, the circuit is not considered to
be adequately protected and the test is carried out with the fuse-link short-circuited;
– is at least 2,75 times the rated current of the fuse-link, the circuit is considered to be
adequately protected;
– is between 2,1 times and 2,75 times the rated current of the fuse-link, the fuse link is
short-circuited and the test is carried out
? for the relevant period or for 30 min, whichever is the shorter, for quick acting fuselinks;
? for the relevant period or for 2 min, whichever is the shorter, for time lag fuse-links.
NOTE 1 In case of doubt, the maximum resistance of the fuse-link has to be taken into account when determining
the current.
NOTE 2 The verification whether the fuse-link acts as a protective device is based on the fusing characteristics
specified in IEC 60127, which also gives the information necessary to calculate the maximum resistance of the
fuse-link.
NOTE 3 Other fuses are considered to be intentionally weak parts in accordance with 19.1.
分析方法如下:
1、 明确熔断器的设置,是用于在何种电子线路故障时起保护作用;
2、 计算或者测试,在单一故障发生的情况下,通过熔断器的电流;
3、 测试和选择方法:
1)、用电流表代替熔断器的两端,逐个模拟单一故障,记录电流表的测试值;
2)、电流表代替时,应充分考虑电流表与熔断器电阻的差异,尽量做到两者内阻相等;
3)、用电流表测得的电流值(选取模拟故障时,需要熔断器动作来保护的最小电流值),除以2.75,所得出的值为熔断器的最大额定电流;
4)、熔断器的额定电流,必须大于电子线路正常工作时通过熔断器位置的电流。(考虑正常电压波动,测量正常工作电流时,输入电压为AC240V,50Hz)。
4、当按照测试值采用了熔断器之后,须进行验证。若模拟电子线路故障是,熔断器立即动作,则在同样条件下重复测试一次,作为薄弱位置的可靠保护确认。
抛砖引玉,请高手完善。
发表于 2011-12-27 11:47:46 | 只看该作者
为什么要除以2.75了?
我在网上找的资料说是选取FUSE为正常电流的1.5-2倍。
有标准要求异常测试时,熔断器电流和额定电流比为小于等于4A的 要大于2。1倍
4到等于10A的要大于1.9
10到25A的要大于1.75
发表于 2011-12-27 11:47:58 | 只看该作者
楼主,如果保险丝仅仅是用来防止L、N之间短路(比如LN之间有一个电容,要做短路测试),这时候FUSE的值怎么定?
LN之间的短路电流一般是多少?这个我没测过,因为怕电流表烧坏,而且也没有时间读数(瞬间就会跳闸)。
 楼主| 发表于 2011-12-27 11:48:08 | 只看该作者
不好意思,这个问题我也搞不清楚,所以需要大家一起讨论啊。
对于防止L,N之间的短路到fuse,是会经常用到的,我曾经看过一份资料,对此方面的原理阐述很多,但是现在也忘记了。fuse的选择,我上面说的肯定是不完善的,你所提的需要考虑电网的保护非常有道理。
不过对于你说到L,N之间的电容,根据标准24.1.1的要求:可能永久承受电源电压的电容,一般要求用IEC 60384-14标准的电容,即X2电容,这种电容是不用做短路测试的。
最有可能碰到的,是在L,N端加压敏电阻,用于通过EMC测试,由于压敏电阻长期使用之后,会产生累计效应,这个时候一般要求在前端加一个fuse的。
发表于 2011-12-27 11:48:19 | 只看该作者
提供一点信息:
我以前在电容厂看过,压敏电阻和Y电容的生产工艺是一模一样的,甚至命名都是一样的,如471,103等等。只是做认证的时候把它分不同的标准来认证(当然工艺、材料也可能有区别,但就我这外行来看是一样的)。
更正一下:我在网上查了一下,压敏电阻和Y电容用的材料还是不一样的。压敏电阻常用氧化锌,Y电容用高压瓷片。我也想起来,厚度也不一样,压敏电阻比较薄,Y电容厚一些(爬电要求)。但是,命名确实是类似的,我不知道是为什么。
GMT+8, 2026-10-18 13:59 , Processed in 0.028783 second(s), 18 queries , Gzip On.
