查看: 1089|回复: 4
INSPECTION PROGRAM
发表于 2007-9-8 16:14:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
*Verify the lot /random ,enough./sign on carton etc.
5)carton check
workmanship, pkg.easily take out .asst ratio /carton mark /single or 2 wall follow si ,upc position ,scan .no check /carton abuse and check etc
6)pkg check
marking and lauguage to the country /pkg. label check if any /workmanship /pkg. easily open check by qc
pkg. stand-able ./try me /upc scan and check against////etc.
6)parts check
workmanship of safety /aesthetics .function performance and measurement /missed or wrong part./fitting check /instruction comparison/date code or  batch code /  B/o toy batterry box check
7) data  check
DB check /current. voltage/ operation force/ pvc weight .hardness / polybag thickness /projectile distance
8) safety abuse test
drop /tip over s/s sample status and hand gesture / T/T. sample status and hand gesture / compression .bite test / B/o toy abuse for overheat /pvc curing /sample discard
9)reliablity. abuse test
drop/tip over (need it to do?) .s/s sample status and hand gesture/ T/T(need to do ?)
.s/s sample status and gesture /coating/label adhesion /sample discard
10) Report writing
defect descrition clear, accurate. easily understand .enough information/ remark (carton data .DB data ,sI# etc.
General requirement
/inspection arrangement
in sequence and well control (not easily overlook,missed point) . s/s enough, take photo for DI shipment .and mark and sign on SI
发表于 2009-4-19 09:55:21 | 只看该作者
afas
dfdsfdfdfghhher
发表于 2009-5-11 23:19:19 | 只看该作者
thank you!
发表于 2009-7-5 10:36:49 | 只看该作者
this program is for what kind of product?
发表于 2009-10-19 16:13:54 | 只看该作者
非常感谢!
GMT+8, 2026-11-30 15:28 , Processed in 0.025718 second(s), 18 queries , Gzip On.
