查看: 539|回复: 6
有关PIZZA炉
发表于 2011-12-26 18:38:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大家好!请问PIZZA炉做CE的话是用那个标准呢。是60335-2-36吗?具体正常温升应该怎么做?
发表于 2011-12-26 18:38:53 | 只看该作者
商用的就是60335-2-36
 楼主| 发表于 2011-12-26 18:39:16 | 只看该作者
那请问正常温升应该怎么做。对应标准哪个器具呢?
发表于 2011-12-26 18:39:43 | 只看该作者
按照标准中的Oven要求来做:
Ovens are operated with no load and with the controls set so that the mean value of the temperature over the thermostat cycle at the geometric centre of the usable space in the interior of the oven is maintained at 240 °C ± 4 °C. Stepped controls are set so that this temperature is 240 °C ± 15 °C. For ovens that are capable of attaining temperatures in excess of 290 °C, the controls are set so that the temperature is 50 °C ± 4 °C below the maximum temperature attainable. For ovens that are unable to attain a temperature of 240 °C, the controls are set to maximum.
发表于 2011-12-26 18:40:09 | 只看该作者
如果是家用的话,可以考虑按照contact grill来做。
发表于 2011-12-26 18:40:46 | 只看该作者
都用-36了,怎么家用呢
发表于 2011-12-26 19:18:08 | 只看该作者
商用的就是60335-2-36
GMT+8, 2026-10-18 13:45 , Processed in 0.034054 second(s), 18 queries , Gzip On.
