查看: 625|回复: 5
EN60335-2-14: 2008
发表于 2011-12-26 16:45:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问,有人知道EN60335-2-14 A1:2008 中需要增加哪些测试吗? 2008版中增加了哪些方面??
谢谢
发表于 2011-12-26 16:46:26 | 只看该作者
测试基本没增加,主要是下面两个地方加了些内容:
11.7 Replacement:
The appliance is operated for the period specified and where relevant the number of cycles specified.
NOTE 1 When using rated power input as the load (as per 3.1.9 Note 103), the period for which rated power input is applied must, for some functions or kitchen machines, be determined by first applying the load detailed in 3.1.9. For example
? the period in 11.7.104 is obtained using the load in 3.1.9.103;
? the period in 11.7.106 is obtained using the load in 3.1.9.105;
? the period in 11.7.108 is obtained using the load in 3.1.9.108;
? the period in 11.7.111 is obtained using the load in 3.1.9.111 (for food processors when instructions for mixing yeast dough are not provided);
? the period in 11.7.112 is obtained using the load in 3.1.9.112;
? the period in 11.7.116 is obtained using the load in 3.1.9.117 (for other than hand-held potatoe peelers);
? the period in 11.7.117 is obtained using the load in 3.1.9.118.
NOTE 2 When using rated power input as the load (as per 3.1.9 Note 103) and if instructions for mixing yeast dough are provided, the number of cycles to be applied in 11.7.111 is found by first ascertaining the number of cycles necessary to process at least 1 kg of flour using the load in 3.1.9.111.
If this period exceeds that stated in the instructions and if the temperature rise limits of Table 3 are exceeded, the test is carried out for the number of cycles specified and using the maximum quantity of the load to be processed stated in the instructions for
? the maximum period stated in the instructions plus 1 min, for specified operating periods not exceeding 7 min;
? the maximum period stated in the instructions, for specified operating periods exceeding 7 min.
If it is necessary to perform a number of operations to obtain these periods, the rest periods are equal to, where relevant, the time taken to empty and refill the container with the maximum quantity of ingredients stated in the instructions.
Appliances incorporating a timer are operated for the maximum period allowed by the timer.
20.106那里加了句:the feed screw of the appliance shall not be accessible to test probe B of IEC 61032 with the pusher in position.
发表于 2011-12-26 16:46:53 | 只看该作者
增加了电饭锅的详细测试方法 其他器具如常
发表于 2011-12-26 16:47:15 | 只看该作者
电饭煲,用-2-14吗/
发表于 2011-12-26 16:47:38 | 只看该作者
是的,都属于液体加热器这一类的。
发表于 2011-12-26 16:47:59 | 只看该作者
电饭煲不是用-2-15吗?
才是液体加热器具
-2-14是马达类的吧
GMT+8, 2026-10-18 12:52 , Processed in 0.028209 second(s), 19 queries , Gzip On.
