查看: 361|回复: 2
举实例,怎样理解 IEC 60335-2-80 cl 22.2?
发表于 2011-12-24 13:53:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
For stationary appliances, means shall be provided to ensure all-pole disconnection from the supply mains. Such means shall be one of the following:
- a supply cord fitted with a plug;
- a switch complying with 24.3;
- a statement in the instructions that a disconnecton incorporated in the fixed wiring is to be provided;
- an appliance inlet.
Single-pole switches, and single-pole protective devices that disconnect heating elements from the supply mains, in single-phase,permanently connected class I appliances shall be connected to the phase conductor.
compliance is checked by inspection.
家用吊扇上装的只有单极拉线开关,墙上没有装控制风扇的开关,请问这种结构合格吗?
发表于 2011-12-24 13:53:52 | 只看该作者
家用吊扇上装的只有单极拉线开关,墙上没有装控制风扇的开关,这种结构是不符合标准要求的.
一般要求说明书有如22.2中的:
 楼主| 发表于 2011-12-24 13:54:29 | 只看该作者
一般要求说明书有如22.2中的:
正做认证的这款吊扇是不配墙上开关装置的。
在说明书中写上a statement in the instructions that a disconnecton incorporated in the fixed wiring is to be provided是让客户再买个开关装在墙上是吧?
GMT+8, 2026-10-18 12:39 , Processed in 0.027938 second(s), 18 queries , Gzip On.
