查看: 366|回复: 1
Separate controls are mounted on a dull black-painted plywoo
发表于 2011-12-23 19:19:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
IEC 60335-2-80
19.7 Addtion:
Separate controls are mounted on a dull black-painted plywood board. Approximately 50% of the area of each ventilating opening is blocked. The temperature of windings shall not exceed the values specified in Table 8 and the temperature rise of the board shall not exceed
- 50K, for appliances with T marking;
- 65K, for other appliances.
其中:Separate controls are mounted on a dull black-painted plywood board.
该测试怎么做?
发表于 2011-12-23 19:19:42 | 只看该作者
你的是什么风扇?
一般只有吊扇,duct fan 或固定的风扇线路从墙里面走的才有separate controls(也就是装在墙上的开关。)
这个应该很容易理解的。
GMT+8, 2026-10-18 12:25 , Processed in 0.050294 second(s), 18 queries , Gzip On.
