查看: 891|回复: 2
关于白炽灯做MEPS事宜
发表于 2011-12-23 14:07:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
昨天有客户咨询白炽灯做澳洲MEPS,特贴出来与大家分享,白炽灯做MEPS需确定产品是否在以下范围内:
GLS tungsten filament
(a) Shapes: A50-A65, PS5O-PS65, M50-M65, T50-T65 (as generally outlined in IEC 60630) or E50-E65.
(b) Caps: E14, E26, E27, B15 or B22d.
(c) Nominal voltage > 220 V.
(d) Nominal wattage <150 W.
(e) Not including coloured lamps, reflector lamps, crown-reflector lamps or lamps with a halogen gas fill.
ELV (extra low voltage) halogen non-reflector
(a) Tungsten halogen lamp burner.
(b) Shapes: single-ended capsule, non-reflector.
(c) Caps: bi-pin.
(d) Nominal voltage 5 – 14 V inclusive.
(e) Not including coloured lamps, reflector lamps or crown-reflector lamps.
Candle tungsten filament
(a) Shapes: candle or B (as generally outlined in IEC 60630) including twisted and bent- tip candle).
(c) Nominal voltage >220 V.
(d) Not including coloured lamps, reflector lamps, crown-reflector lamps or lamps with a halogen gas fill.
Fancy round tungsten filament
(a) Shapes: round, P (as generally outlined in IEC 60630), G or globe.
(d) Not Including coloured lamps, reflector lamps, crown-reflector lamps or lamps with a halogen gas fill.
Decorative lamps tungsten filament
(a) Shapes: decorative shapes.
(d) Not including coloured lamps, reflector lamps, crown-reflector lamps, pilot lamps, lamps with a halogen gas fill or lamps with shapes defined in the previous categories.
Mains voltage halogen non-reflector
(a) Tungsten halogen lamp burner, non-reflector.
(b) Shapes: single-ended.
(c) Caps: E14, E26, E27, B15 or B22d.
(d) Nominal voltage >220 V.
ELV halogen reflector
(a) Tungsten halogen lamp burner, reflector.
(b) Shapes: MR 11-16.
(c) Caps: Bi-pin.
(d) Nominal voltage 5 – 24 V (inclusive).
(e) Not including coloured lamps.
Mains voltage reflector (including halogen)
(a) Tungsten filament or tungsten halogen lamp burner, with reflector.
(b) Shapes: PAR, ER, RE, XR, YR, ZR or MR 11-16
(c) Caps: E14, E26, E27, B15, B22d or GU1O.
更多交流可以加Q:1473395008或Tel:18028705565(深圳)13128038578(东莞)
 楼主| 发表于 2012-1-12 15:07:37 | 只看该作者
大家什么时候放年假?
 楼主| 发表于 2012-2-11 10:11:59 | 只看该作者
新的一年,新的开始,祝大家一切顺利!!!
GMT+8, 2026-11-10 10:16 , Processed in 0.087611 second(s), 18 queries , Gzip On.
