查看: 311|回复: 1
请问确定工作电压时如何考虑谐振电压的影响?
发表于 2011-12-22 19:01:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
IEC 60335
3.1.3 working voltage
maximum voltage to which the part under consideration is subjected when the appliance is supplied at its rated voltage and operating under normal operation
NOTE 1 The different positions of controls and switching devices are taken into account.
NOTE 2 Working voltage takes into account resonant voltages.
NOTE 3 When deducing the working voltage, the effect of transient voltages is ignored.
提到确定工作电压时应该考虑谐振电压。
请问谐振电压在什么情况下出现?
什么产品中出现?
如果存在的话,如何计算工作电压?
发表于 2011-12-22 19:01:45 | 只看该作者
例:电容感应式电动机的副绕组与电容器串联会发生谐振,使电容器两端的工作电压比器具的额定电压高许多。
GMT+8, 2026-10-18 12:04 , Processed in 0.049631 second(s), 19 queries , Gzip On.
