查看: 525|回复: 4
电磁炉按键测试
发表于 2011-12-21 23:07:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
22.113 Hobs shall be constructed so that inadvertent operation of touch controls is unlikely
if this could give rise to a hazardous situation due to
– spillage of liquids, including that caused by a vessel boiling over;
– a damp cloth placed on the control panel.
Compliance is checked by the following test, the appliance being supplied at rated voltage.
The test is carried out with each hob element energized in turn and then without energizing
any hob elements.
Sufficient water to completely cover the control panel to a depth not exceeding 2 mm, with a
minimum of 140 ml, is poured steadily over the control panel so that bridging occurs between
combinations of touch pads.
A cloth having a mass between 140 g/m2 and 170 g/m2, and dimensions approximately
400 mm x 400 mm, is folded four times into a square pad, saturated with water and placed
over the control panel in any position.
There shall be no operation of any hob element for longer than 10 s.
During the test, it shall be possible to switch off the energized hob element by operating the
touch controls, unless it switches off automatically.
这是335-2-6的标准原话. 对这个测试不是很清楚. 足够的水覆盖在控制面板上后, 在用140ml的水倾倒上去, 还有个就是模拟抹布在控制面板上移动. 电磁炉要在额定电压下工作的情况下做这个测试?如何判定这个测试?
发表于 2011-12-21 23:07:18 | 只看该作者
这个就是泼洒试验
之前做过类似的测试(医疗产品)产品在开机状态泼洒,测试后用棉布抹去可见水,马上进行漏电流和耐压测试。
 楼主| 发表于 2011-12-21 23:07:25 | 只看该作者
不是吧? 335-2-6的21.102才是你说的测试吧?考量面板的测试
发表于 2011-12-21 23:07:31 | 只看该作者
该测试是检验触摸控制的面板会不会有误操作引起的危险.试验时,先使每个炉头依次通电,然后所有炉头不通电.将足够覆盖控制面板但不超过2mm深的水,最小量为140mL,均匀地倒在控制板上,使得组合的按扭件桥接.然后将一块品质为140克/平方米,尺寸为40mm*400mm的浸满水的布经四次折叠成方块放在控制面板的任何位置.任何一灶头不应有超过10秒的运行.
 楼主| 发表于 2011-12-21 23:07:37 | 只看该作者
那如果在倒140ml的水或者使用粘水的布放置在控制面板上, 如果能够使得按键感应, 那不是会造成器具工作. 还有,倒140ml水的时候, 没有规定其高度, 个人觉得高度够的话,是能够激活按键.
GMT+8, 2026-10-18 10:30 , Processed in 0.036788 second(s), 18 queries , Gzip On.
