查看: 315|回复: 0
求助UL1082
发表于 2011-12-21 22:51:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求助UL1082
11章电源线中的pin terminal 这一段怎么看也不明白,请高手解释解释,在此谢过!!
11.3.2 A pin guard is required, such that:
a) A straight edge placed in any position, across and in contact with edges of the plug opening without the plug in place, cannot be made to contact any current-carrying pin.
b) With the plug aligned with the pins and the face of the plug in a plane located perpendicular to the end or ends of the farthest projecting current–carrying pin, the probe illustrated in Figure 7.2 should not touch any current-carrying pin while the probe is inserted through any opening with the appliance in any position.
GMT+8, 2026-10-18 09:44 , Processed in 0.027467 second(s), 18 queries , Gzip On.
