查看: 1444|回复: 10
自己总结的验货经验,求精。英文不好的可能有点吃力,免费服务大众。
发表于 2011-12-21 18:38:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Guide-line for apparel inspection
Initial production inspection (IPI) normally required:
10-20% products finished
During production inspection (DPI)normally required:30-50%
products finished
Final random inspection (FRI)normally required: 100% productsfinished 80% were packed into cartons
If FRI shipment qtywas over +/- 5% ,
Informclients and stand by till clients’ further instructions.
IPI,DPI :
inspection bulk size = produced qty
FRI : inspectionbulk size= shipment qty;
FRI selected andinspected cartons qty﹥=√shipment cartons qty (then round this number up), if the selectedcarton sample number could not met the requirement, select more cartons untilrequirement fulfilled.
Inspected samplesize = L2 (details please refer to AQL table)
Workmanship checking
Sample size = L2
Critical = 0
Major =2.5
Minor =4.0
Any kind of defectshould be taken at least two photos, one for serious and one for slight. Ifresult was failed due to workmanship beyond AQL, seal the major defectivesample for client further confirmation.
发表于 2011-12-21 20:01:01 | 只看该作者
有些单词连在一起,就不认识了。是不是考大家的?
发表于 2011-12-21 21:21:15 | 只看该作者
The "could not met the" should be "meet the" .  The(AQL table) should be"AQL label
呵呵,这些是英文中的错别字,不过LZ很热心把验货基本要求写出来了。
发表于 2011-12-21 23:12:41 | 只看该作者
楼主好人,收藏了,俺们同行
发表于 2011-12-21 23:13:44 | 只看该作者
同行啊,深圳服装验货员。
额,不过现在在求职
发表于 2011-12-22 22:11:26 | 只看该作者
回复 3# worldlink 的帖子
呵呵!是我看错了!用这些单词也可以,是这些意思就行!
对不起LZ了。
 楼主| 发表于 2011-12-27 13:56:00 | 只看该作者
不知道为什么在word文档里单词都是编辑好的,但是在帖子里就有些单词连在一起了,对不起大家,不是考大家的。
发表于 2011-12-27 14:33:10 | 只看该作者
回复 7# myqcsister 的帖子
单词有没有连在一起,大家看的出来!LZ 不用自责.
发表于 2011-12-28 21:44:46 | 只看该作者
事情用心做就是不一样
发表于 2011-12-29 01:11:20 | 只看该作者
Thanks for your sharing!!
GMT+8, 2026-9-26 00:48 , Processed in 0.030638 second(s), 17 queries , Gzip On.
