查看: 497|回复: 5
双手控制距离的考量
发表于 2011-12-21 18:31:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题:双手控制按钮的距离有规定要达到多少吗?
发表于 2011-12-21 18:31:38 | 只看该作者
EN 574 Two-hand control devices 看下这个标准,里面有规定
发表于 2011-12-21 18:31:45 | 只看该作者
等高手出现,指点迷经
发表于 2011-12-21 18:31:51 | 只看该作者
有相关标准。通俗说大于小手臂长度
发表于 2011-12-21 18:31:58 | 只看该作者
双手控制按钮的类别在实际检测中如何鉴定?
发表于 2011-12-21 18:32:04 | 只看该作者
分几种情况 (翻译可能不准确,所以直接用英文)
1. Prevention of defeat using one hand, 距离是>=260mm
2.Prevention of defeat using hand and elbow of the same arm,距离是>=550mm
3.Prevention of defeat using the forearm(s) or elbow(s), required
- Shields designed in such a way that the control actuating devices cannot be operated by the forearms and/or the elbows
4. Prevention of defeat using the hand and other parts of the body, required by
- Arrangement of the control actuating devices on a horizontal or nearly horizontal surface at least 1100 mm above floor or level of access
- Arrangement of the control actuating devices on a vertical or nearly vertical surface with protective collar(s) around the control actuating devices and/or shield(s)
- Covers and/or shields
GMT+8, 2026-11-16 03:12 , Processed in 0.065849 second(s), 18 queries , Gzip On.
