查看: 781|回复: 5
机械指令-油压千斤顶的问题
发表于 2011-12-20 22:16:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我有一款设备,油压千斤顶,问了一些代理,和实验室,他们说如果用在汽车上,那么就属于危险机械,很多机构就不能做.请问是这样的吗?哪里能做这个测试?有些机构给我报价25000一款,请问贵吗?
发表于 2011-12-20 22:16:43 | 只看该作者
原文 机械指令的问题 :
看看机械指令的annex IV, 看是否在其范围内
发表于 2011-12-20 22:16:51 | 只看该作者
没错, 你的是危险产品, 要做型式认证:
Products
Found : 49
Search criteria :
Directive : 98/37/EC Machinery
Article or annex : Annex VI Art.8, 2(b) and 2c, 3rd indent
Procedure : EC Type-examination
Show full list
  Automatic movable protective fitting for machines in accordance with Annex IV A, nrs 9-11
  Automatic movable screens to protect the presses referred to in 9, 10 and 11 (section B3 of annex IV)
  Band-saws with a fixed or mobile bed and band-saws with a mobile carriage, with manual loading and/or unloading, for working with foodstuffs such as meat, fish and deep-frozen products (part of section A4 of annex IV)
  Band-saws with a fixed or mobile bed and band-saws with a mobile carriage, with manual loading and/or unloading, for working with wood (section A4 of annex IV)
  Band-saws with a fixed or mobile bed and band-saws with a mobile carriage, with manual loading and/or unloading, for working with wood and analogous materials (part of section A4 of annex IV)
  Band-saws with a fixed or mobile bed and band-saws with a mobile carriage, with manual loading and/or unloading, for working with wood and analogous materials or for working with meat and analogous materials (section A4 of annex IV)
  Band-saws with a fixed or mobile bed and band-saws with a mobile carriage, with manual loading, for working with meat and analogous materials (part of section A4 of annex IV)
  Circular saws (single or multi-blade) for working with foodstuffs such as meat, fish and deep-frozen products : (part of section A1 of annex IV)
  Circular saws (single or multi-blade) for working with meat and analogous materials : (part of section A1 of annex IV)
  Circular saws (single or multiblade) for working with wood and analogous materials : (part of section A1 of annex IV)
  Circular saws (single- or multiblade) for working with wood (section A1 of annex IV)
  Circular saws (single- or multiblade) for working with wood and analogous materials or for working with meat and analogous materials : (section A1 of annex IV)
  Combined machines of the types referred to in 1 to 4 and 7 for working with wood (section A5 of annex IV)
  Combined machines of the types referred to in 1 to 4 and 7 for working with wood and analogous materials (section A5 of annex IV)
  Control units with safety functions for two-hand control devices
  Devices for the lifting of persons involving a risk of falling from a vertical height of more than 3 metres (section A16 of annex IV)
  Devices for the lifting of persons involving a risk of falling from a vertical height of more than 3 metres (section A16 of annex IV) (Restricted to mobile elevating work platforms)
  Electro-sensitive devices designed specifically to detect persons in order to ensure their safety (non-material barriers, sensor mats, electromagnetic detectors, etc.) (section B1 of annex IV)
  Falling-object protective structures (FOPS) (section B5 of annex IV)
  For all machines and safety components listed in Annex IV
  For all machines listed in annex IV
  For all machines listed in annex IV (except A15 and A16)
  For all machines listed in annex IV.A (except A16 and A17)
  For all products listed in annex IV
  Guards and detachable transmission shafts with universal joints as described in section 3.4.7. (section A14 of annex IV)
  Hand-fed surface planing machines for woodworking (section A2 of annex IV)
  Hand-fed tenoning machines with several tool holders for woodworking (section A6 of annex IV)
  Hand-fed vertical spindle moulding machines for working with wood and analogous materials (section A7 of annex IV)
  Injection or compression plastics-moulding machines with manual loading or unloading (section A10 of annex IV)
  Injection or compression rubber-moulding machines with manual loading or unloading (section A11 of annex IV)
  Logic units which ensure the safety functions of bi-manual controls (section B2 of annex IV)
  Machinery for underground working of the following types : (part of section A12 of annex IV)
  Machinery for underground working of the following types : (section A12 of annex IV)
  Machines for the manufacture of pyrotechnics (section A17 of annex IV)
  Manually-loaded trucks for the collection of household refuse incorporating a compression mechanism (section A13 of annex IV)
  Portable chainsaws for woodworking (section A8 of annex IV)
  Presses, including press-brakes, for the cold working of metals, with manual loading and/or unloading, whose movable working parts may have a travel exceeding 6 mm and a speed exceeding 30 mm/s. (section A9 of annex IV)
  Roll-over protection structures (ROPS) (section B4 of annex IV)
  Safety components in accordance with Annex IV B, nr 3
  The following machines are restricted to those that are electrically operated and with an effect not exceeding 4 kW.
  Thicknessers for one-side dressing with manual loading and/or unloading for woodworking (section A3 of annex IV)
  Vehicles servicing lifts (section A15 of annex IV)
  hydraulic-powered roof supports
  internal combustion engines to be fitted to machinery for underground working
  machinery on rails: locomotives and brake-vans
  sawing machines with fixed tool during operation, having a built-in mechanical feed device for the workpieces, with manual loading and/or unloading
  sawing machines with fixed tool during operation, having a fixed bed with manual feed of the workpiece or with a demountable power feed
  sawing machines with fixed tool during operation, having a manually operated reciprocating saw-bench or carriage
  sawing machines with movable tool during operation, with a mechanical feed device and manual loading and/or unloading
发表于 2011-12-20 22:16:57 | 只看该作者
Bodies
Found : 88
Search criteria :
Product family, product /Intended use : Vehicles servicing lifts (section A15 of annex IV)
Body type Name  Country
NB 0026 AIB-VINÇOTTE INTERNATIONAL S.A.
Belgium
NB 0032 TÜV NORD CERT GMBH & CO. KG
Germany
NB 0034 TÜV SAARLAND E.V.
Germany
NB 0035 TÜV RHEINLAND INDUSTRIE SERVICE GMBH
Germany
NB 0036 TÜV SÜD Industrie Service GmbH
Germany
NB 0040 ROYAL & SUN ALLIANCE INSURANCE PLC(TRADING AS ROYAL & SUN ALLIANCE CERTIFICATION SERVICES)
United Kingdom
NB 0041 BUREAU VERITAS INSPECTION LIMITED
United Kingdom
NB 0044 TÜV NORD CERT GmbH
Germany
NB 0051 IMQ ISTITUTO ITALIANO DEL MARCHIO DI QUALITÀ S.P.A.
Italy
NB 0062 BUREAU VERITAS
France
NB 0066 ISTITUTO DI CERTIFICAZIONE EUROPEA PRODOTTI INDUSTRIALI S.P.A.
Italy
NB 0068 IRCM ISTITUTO DI RICERCHE E COLLAUDI MASINI S.R.L.
Italy
NB 0099 ASOCIACION ESPAÑOLA DE NORMALIZACION Y CERTIFICACION (AENOR)
Spain
NB 0121 BGIA - BERUFSGENOSSENSCHAFTLICHES INSTITUT FÜR ARBEITSSCHUTZ
Germany
NB 0123 TÜV SÜD Product Service GmbH
Germany
NB 0125 LGA QualiTest GMBH
Germany
NB 0197 TÜV RHEINLAND PRODUCT SAFETY GMBH
Germany
NB 0344 KEMA Quality B.V.
Netherlands
NB 0353 SGS UNITED KINGDOM LTD
United Kingdom
NB 0359 INTERTEK TESTING & CERTIFICATION LTD
United Kingdom
NB 0397 ORGANISMO DI CERTIFICAZIONE EUROPEA SRL
Italy
NB 0398 CPM - ISTITUTO RICERCHE PROVE ED ANALISI SRL
Italy
NB 0399 ABOMA + KEBOMA B.V.
Netherlands
NB 0400 LIFTINSTITUUT B.V.
Netherlands
NB 0404 SVENSK MASKINPROVNING AB - SMP
Sweden
NB 0407 ISTITUTO GIORDANO S.P.A.
Italy
NB 0408 TÜV- ÖSTERREICH
Austria
NB 0409 Inspecta Sweden AB
Sweden
NB 0417 FACHAUSSCHUß "VERKEHR"
Germany
NB 0424 Inspecta Tarkastus Oy
Finland
NB 0425 ICIM - ISTITUTO DI CERTIFICAZIONE INDUSTRIALE PER LA MECCANICA S.P.A.
Italy
NB 0426 CONSORZIO ITALCERT
Italy
NB 0432 MATERIALPRÜFUNGSAMT NORDRHEIN-WESTFALEN (MPA NRW)
Germany
NB 0463 AMTRI VERITAS LIMITED
United Kingdom
NB 0474 RINA S.P.A.
Italy
NB 0495 INDUSTRIAL ENGINEERING CONSULTANTS SRL
Italy
NB 0496 CONSORZIO DNV - MODULO UNO SCRLS
Italy
NB 0505 VENETA ENGINEERING SRL
Italy
NB 0529 ISTEDIL SPA - ISTITUTO SPERIMENTALE PER L'EDILIZIA
Italy
NB 0537 VTT (TECHNICAL RESEARCH CENTRE OF FINLAND)
Finland
NB 0572 FINN STRØM A.S.
Norway
NB 0599 ELECTRICAL INSPECTION FIMTEKNO OY
Finland
NB 0640 ÅF- KONTROLL AB
Sweden
NB 0654 TUV HELLAS S.A.
Greece
NB 0683 KONHEF vzw
Belgium
NB 0714 EUROPEAN CERTIFYING ORGANIZATION S.P.A.
Italy
NB 0861 EUROCERT SRL
Italy
NB 0865 ISTITUTO SERVIZI EUROPEI TECNOLOGICI SRL
Italy
NB 0867 TÜV THÜRINGEN ANLAGENTECHNIK GMBH - ZERTIFIZIERUNGSSTELLE FÜR GERÄTESICHERHEIT
Germany
NB 0869 SLP Lyft & Elprovning i Sverige AB
Sweden
NB 0870 LAIDLER CERTIFICATION
United Kingdom
NB 0877 APAVE NORD-OUEST
France
NB 0897 SEUCER SRL
Italy
NB 0899 EUCERT ORGANISMO DI CERTIFICAZIONE EUROPEO DI SIMONELLI LIBORIO SRL
Italy
NB 0901 I.N.C.S.A. SRL - ISTITUTO NAZIONALE CONTROLLO SICUREZZA ASCENSORI
Italy
NB 0905 INTERTEK DEUTSCHLAND GMBH
Germany
NB 0929 RISKPLANT CONSULTANTS PTY LTD
Australia
NB 0948 TUV ITALIA SRL
Italy
NB 1008 TÜV RHEINLAND INTERCERT KFT.
Hungary
NB 1015 STROJIRENSKY ZKUSEBNI USTAV s.p.
Czech Republic
NB 1016 STATNI ZKUSEBNA ZEMEDELSKYCH POTRAVINARSKYCH A LESNICKYCH STROJU, AKCIOVA
Czech Republic
NB 1017 TÜV SÜD Czech s. r. o.
Czech Republic
NB 1028 INGENIERIA DE GESTION INDUSTRIAL, S.L. (INGEIN)
Spain
NB 1105 CCQS UK LTD
United Kingdom
NB 1294 SÚDST S.R.O.
Slovakia
NB 1299 Technicky skusobny ustav Piestany s.p.
Slovakia
NB 1304 SLOVENIAN INSTITUTE OF QUALITY AND METROLOGY - SIQ
Slovenia
NB 1353 TÜV SÜD SLOVAKIA s.r.o.
Slovakia
NB 1354 TECHNICKA INSPEKCIA, a.s.
Slovakia
NB 1356 ZV - TEST S.R.O
Slovakia
NB 1357 Skusobna ocelovych lan - Fakulta BERG TU v Kosiciach
Slovakia
NB 1358 VYSKUMNY USTAV DOPRAVNY, A.S.
Slovakia
NB 1399 TECHNICAL SUPERVISION SERVICE
Lithuania
NB 1400 CERTIFICATION BODY FOR MACHINES OF THE STATE MACHINES TESTING STATION
Lithuania
NB 1416 EGMI EPITOGEPIPARI MINOSEGVIZSGALO ES MUSZAKI SZOLGALTATO KFT.
Hungary
NB 1417 EMI-TUV BAYERN MINOSEGUGYI ES BIZTONSAGTECHNIKAI KFT.
Hungary
NB 1423 TUV NORD-KTI MUSZAKI ELLENORZO ES SZOLGALTATO KFT.
Hungary
NB 1433 URZAD DOZORU TECHNICZNEGO (UDT)
Poland
NB 1457 PRZEMYSLOWY INSTYTUT MASZYN BUDOWLANYCH (PIMB)
Poland
NB 1468 TRANSPORTOWY DOZOR TECHNICZNY (TDT)
Poland
NB 1635 PLC SRL
Italy
NB 1729 CTE CERTIFICAZIONI SRL
Italy
NB 1752 CERTAT
Italy
NB 1760 S.C.E.C. E S. SRL
Italy
发表于 2011-12-20 22:17:03 | 只看该作者
NB 1804 Institutul National de Cercetare-Dezvoltare pentru Masini si Instalatii destinate Agriculturii si Industriei Alimentare
Romania
NB 1805 Institutul National de Cercetare-Dezvoltare pentru Protectia Muncii "Alexandru Darabont"
Romania
NB 1871 CENTER FOR TESTING AND EUROPEAN CERTIFICATION Ltd.
Bulgaria
NB 1878 VERICERT
Italy
发表于 2011-12-20 22:17:09 | 只看该作者
哇~就算不做危险机械~当ㄧ般机械处理也很划算吧!
但是要看他所报价的规范 ~ 因为台湾有些厂商只做某ㄧ指令差不多也报这个价位!
在台湾懂得多~报价不见得能拉高 (原因也在这~只报单一指令唉)!
不过您要注意了~ 这个价位要处理危险机械 恐怕有问题!
(据了解~光发证单位的费用好像都比25000多喔) 难道测试写技术文件不用钱吗?
建议多问一些单位!
GMT+8, 2026-11-16 21:59 , Processed in 0.090697 second(s), 18 queries , Gzip On.
