查看: 664|回复: 5
带有器具输入插座的产品属于X连接吗?
发表于 2011-12-10 15:47:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一般的电饭锅所用的器具输入插座与分离式电源线,是属于X连接吗?之前经请教高手,被告知这属于Pin连接,不属于X连接。
可是60335中:
25.5 Supply cords shall be assembled to the appliance by one of the following methods:
– type X attachment;
– type Y attachment;
– type Z attachment, if allowed in the relevant part 2.
Type X attachments, other than those having a specially prepared cord, shall not be used for
flat twin tinsel cords.
Compliance is checked by inspection.
这段话是否意味着器具只能用这三种连接方式中的一种?如果是又如何界定普通电饭锅的电源连接方式?请高人不吝告知,小弟不胜感激!
发表于 2011-12-10 15:48:12 | 只看该作者
type X attachment
发表于 2011-12-10 15:49:03 | 只看该作者
先看25.1:
25.1 Appliances, other than those intended to be permanently connected to fixed wiring,
shall be provided with one of the following means for connection to the supply mains:
– supply cord fitted with a plug;
– an appliance inlet having at least the same degree of protection against moisture as
required for the appliance;
– pins for insertion into socket-outlets
首先是电源的连接,你的器具采用的是“an appliance inlet ”连接方式,“Supply cords ”并不和器具直接连接,所以25.5并不适用。
注意电源连接和电源线连接的区别。先确定电源连接的方式,再考虑电源线。
发表于 2011-12-10 15:49:52 | 只看该作者
用户被禁言,该主题自动屏蔽!
发表于 2011-12-10 15:50:43 | 只看该作者
不属于X型连接
发表于 2011-12-10 15:51:35 | 只看该作者
不可拆线器具输入插座是什么?有这个的存在吗?还是第一次听说,学习下
GMT+8, 2026-10-18 08:54 , Processed in 0.044903 second(s), 18 queries , Gzip On.
