查看: 564|回复: 5
这段标准怎么理解,谢谢(摘自IEC 60335-2-24)
发表于 2011-12-9 20:13:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
13.2 Modification:
Instead of the values specified for class 0I appliances and the various types of class I
appliances, the following values apply:
– for class 0I appliances 0,75 mA;
– for class I refrigerating appliances the values specified for the various types of
stationary class I appliances;
– for other class I appliances 1,5 mA.
发表于 2011-12-9 20:13:28 | 只看该作者
泄漏电流限制做了如下变化:
OI类由原0.5改为0.75;
I类制冷器具refrigerating appliance,泄漏电流限制采用相应的驻立式I类(stationary class I)器具的要求(一般为3.5);
其它I类器具(如ice-maker,ice-cream appliance)为1.5
发表于 2011-12-9 20:13:49 | 只看该作者
现在基本没有01类的器具。
(ice-maker,ice-cream appliance)属于refrigerating appliance
-相应的驻立式I类
-其他的不是stationary 的I类器具(一般小于40KG的非fixed 或者built-in 的器具如cooler and warmer(车载冰箱))
发表于 2011-12-9 20:14:10 | 只看该作者
“(ice-maker,ice-cream appliance)属于refrigerating appliance”
以上说法是不正确的。
详见定义:
3.101
enclosed thermally insulated appliance of suitable volume for household use, cooled by an
incorporated device and having one or more compartments intended for the preservation of
foodstuffs
3.103
ice-maker
appliance in which ice is made by freezing water by a device consuming electrical energy and
having a compartment for storing the ice
3.110
ice-cream appliance
compression-type appliance which is used to make ice-cream
区别在于ice-maker,ice-cream appliance并不具有贮存食品功能。在这里不要因为它有制冷功能就把它等同refrigerating appliance。标准中应依据标准的定义。
发表于 2011-12-9 20:14:30 | 只看该作者
13.2 该条内容作下述修改:
用下述值代替0I类器具和不同类型的I类器具规定的值:
-----0I类器具 0.75mA
----- I 类器具 1.5mA
发表于 2011-12-9 20:35:40 | 只看该作者
回复 5# qing1234 的帖子
楼上说的好~~~~~~~~
GMT+8, 2026-10-18 09:30 , Processed in 0.031645 second(s), 18 queries , Gzip On.
