查看: 354|回复: 1
空调的制冷剂的问题
发表于 2011-12-6 19:29:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问各位大侠,如果在空调的压缩机的标贴上没标明制冷剂的重量,只有型号,比如R43之类的。这样行不?
发表于 2011-12-6 19:30:39 | 只看该作者
根据 60335-2-24 7.1 的要求:
– the total mass of the refrigerant;
– for a single component refrigerant, at least one of the following:
? the chemical name;
? the chemical formula;
? the refrigerant number;
– for a blended refrigerant, at least one of the following:
? the chemical name and nominal proportion of each of the components;
? the chemical formula and nominal proportion of each of the components;
? the refrigerant number and nominal proportion of each of the components;
? the refrigerant number of the refrigerant blend;
– the chemical name or refrigerant number of the principal component of the insulation blowing gas.
可见,需要标明制冷剂的重量。
GMT+8, 2026-10-18 07:20 , Processed in 0.043095 second(s), 18 queries , Gzip On.
