查看: 385|回复: 2
电器温升试验
发表于 2011-12-2 21:47:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
电饭煲 电水壶
发热试验 对放入的 水的温度 有什么要求 冷水什么概念
发表于 2011-12-2 21:49:15 | 只看该作者
15 °C ± 5 °C
虽然11章里没有定义,但见335-2-15的第19.102的急冷实验里有提到用15 °C ± 5 °C的冷水
19.102 Kettles incorporating two self-resetting thermal cut-outs are operated with one of
the thermal cut-outs short circuited. The kettle is operated empty at 0,85 times rated power
input or 1,15 times rated power input, whichever is more unfavourable.
Within 2 s of the other thermal cut-out operating, the kettle is filled with water having a
temperature of 15 °C ± 5 °C. After 1 min, the kettle is emptied.
The test is carried out 100 times.
NOTE Subclause 19.13 is applicable.
发表于 2011-12-2 21:50:12 | 只看该作者
参考part2部分的要求
GMT+8, 2026-10-18 05:58 , Processed in 0.067439 second(s), 18 queries , Gzip On.
