查看: 405|回复: 3
家用厨房电动类电器
发表于 2011-12-1 12:47:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教各位,在UL标准中有没有规定家用厨房电动类电器的功率范围?
发表于 2011-12-1 12:48:20 | 只看该作者
这是UL 1026 输入要求看你用的上不。
31 Power Input Test
31.1 The power input to an appliance shall not be more than 105 percent of its marked rating.
31.2 To determine whether an appliance complies with the requirement in 31.1, the power input is to be measured with the appliance at normal operating temperature under full-load conditions (if required for normal operation), and while connected to a supply circuit adjusted to be the highest of the following:
a) The marked voltage rating, or
b) The highest voltage of the applicable range of voltages specified in 53.1 if the marked voltage is within one of the voltage ranges indicated in 53.1.
If an appliance employs a nonmetallic element (such as carbon), the power input is to be determined for an unused element.
发表于 2011-12-1 12:48:33 | 只看该作者
没有规定家用厨房电动类电器的功率范围!
 楼主| 发表于 2011-12-1 12:50:05 | 只看该作者
但是我用的是UL982标准啦
GMT+8, 2026-10-18 03:04 , Processed in 0.064544 second(s), 18 queries , Gzip On.
