查看: 825|回复: 4
求小家电二类电器UL标准!
发表于 2011-11-28 21:29:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教有哪位有小家电二类电器UL标准!
耐压测试标准要求是多少V!谢谢!
发表于 2011-11-28 21:30:13 | 只看该作者
美标中一般耐压值为1250V即可。
你需要什么标准应明确标准号否则这么给你?你也可以在论坛上搜一下。
发表于 2011-11-28 21:30:59 | 只看该作者
DIELECTRIC WITHSTAND VOLTAGE TEST
1. Each appliance shall withstand without electrical breakdown, as a routine production-line test, the application of a 40-70 Hz potential between (1) the primary wiring, including connected components, and accessible dead-metal parts that are likely to become energized, and (2) between primary wiring and accessible low voltage (42.4 V peak or less) metal parts, including terminals.
METHOD I
The test potential shall be:
A. 1200 V for an appliance rated 250 V or less.
B. 1200 V plus 2.4 times the maximum marked voltage (but not less than 240 V) for an appliance rated at more than 250 V.
The test potential indicated above shall be applied for one (1) s.
是不是如上所述。。。我们实际产品是打1500V 2mA 60s(对地)跟3750V 2mA 60s(对外壳)
 楼主| 发表于 2011-11-28 21:31:57 | 只看该作者
也就是说II电器UL标准耐压同II类电器GB耐压一样!
发表于 2011-11-28 21:32:28 | 只看该作者
5.2 UL1082
a) 耐压试验
样机处于充分加热状态,在带电体与非带电金属部件之间施加交流电势。在5s内,测试电势应从零开始渐渐增加到1000V,并在1000V时维持1分钟。(试验期间所有开关应处于闭合状态)
如果外壳或可接触表面(用试验指可接触的部件) 的材料是绝缘材料,应贴上金属箔,测试电势应加在金属箔与带电体之间。
要求不可发生绝缘击穿现象。
GMT+8, 2026-10-18 04:16 , Processed in 0.027405 second(s), 19 queries , Gzip On.
