查看: 408|回复: 3
IEC60335中的22.32中的这段话怎么解释?(已解决)
发表于 2011-11-28 20:04:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
iec60335中关于判定陶瓷是否紧密烧结中的这段话怎么理解? 先谢过!
The ceramic material is broken into pieces that are immersed in a solution containing 1 g of
fuchsine in each 100 g of methylated spirit. The solution is maintained at a pressure not less
than 15 MPa for a period so that the product of the test duration in hours and the test
pressure in megapascals is approximately 180.
发表于 2011-11-28 20:04:37 | 只看该作者
把陶瓷材料敲碎后浸入每100g甲基化酒精加1g品红的溶液中,溶液维持在某个不小于15Mpa的压力,并且测试的时间(以h为单位)和溶液压力(以Mpa为单位)的乘积不小于180。
发表于 2011-11-28 20:04:53 | 只看该作者
要自己做个设备的
发表于 2011-11-28 20:05:06 | 只看该作者
怎么是之积,应该是之和,用了“and”
GMT+8, 2026-10-18 05:31 , Processed in 0.029938 second(s), 18 queries , Gzip On.
