查看: 562|回复: 5
求助小家电的安规
发表于 2011-11-27 17:53:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大家好!
我想向大家请教电水壶,油炸锅,咖啡壶,搅拌机,电烫斗, 吸尘器,多士炉,三明治等产品的安规.
以及怎么样测试?并且在评估的过程中我应该注意那些问题?(我是在一个采购公司做小家电质量工程师,需要对工厂的产品进行评估)
谢谢大家啊!
发表于 2011-11-27 17:54:16 | 只看该作者
这里有IEC60335http://www./read.php?tid-239.html
发表于 2011-11-27 17:54:32 | 只看该作者
原则上按照335的要求,如果是出美国的,就要参照UL的标准。
7 Marking and instructions.................................................................................................
8 Protection against access to live parts............................................................................
9 Starting of motor-operated appliances ............................................................................
10 Power input and current .................................................................................................
11 Heating ..........................................................................................................................
12 Void...........................................................................................................................
13 Leakage current and electric strength at operating temperature......................................
14 Transient overvoltages ...................................................................................................
15 Moisture resistance ........................................................................................................
16 Leakage current and electric strength.............................................................................
17 Overload protection of transformers and associated circuits ...........................................
18 Endurance......................................................................................................................
19 Abnormal operation ........................................................................................................
20 Stability and mechanical hazards .................................................................................
21 Mechanical strength .....................................................................................................
22 Construction .................................................................................................................
23 Internal wiring...............................................................................................................
24 Components .................................................................................................................
25 Supply connection and external flexible cords ..............................................................
26 Terminals for external conductors.................................................................................
27 Provision for earthing ...................................................................................................
28 Screws and connections ...............................................................................................
29 Clearances, creepage distances and solid insulation ....................................................
30 Resistance to heat and fire...........................................................................................
31 Resistance to rusting....................................................................................................
32 Radiation, toxicity and similar hazards..........................................................................
发表于 2011-11-27 17:54:55 | 只看该作者
其实有问题和大家交流,这里的气氛不错的,而且,刚开始看标准,并没有那么顺利,甚至有点晦涩的
发表于 2011-11-27 22:17:31 | 只看该作者
欢迎热情分享与探讨。
发表于 2011-11-28 13:57:29 | 只看该作者
IEC里面都有。
GMT+8, 2026-10-18 03:04 , Processed in 0.043450 second(s), 18 queries , Gzip On.
