查看: 400|回复: 1
可拆卸部件和不可拆卸部件的疑问
发表于 2011-11-27 13:35:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
GB4706.1(IEC60335-1)定义:
3.6. 1
不可拆卸部件 non-detachable part
只有借助于工具才能取下或打开的部件或能够通过 22. 11试验的部件。
3.6.1
non-detachable part
part that can only be removed or opened with the aid of a tool or a part that fulfills the test of 22.11
3.6.2
可拆卸部件 detachable part
不借助于工具就能取下的部件,按使用说明中的要求可以被取下的部件(即使需要用工具才能将其
取下)或不能通过 22. 11试验的部件。
注 1:为了安装必须取下的部件,即使使用说明中声明用户可取下它,也不认为该部件是可拆卸的。
注2:不借助于工具就能取下的元件,认为是可拆卸部件。
注3:能被打开的部件认为是可取下的部件。
3.6.2
detachable part
part that can be removed without the aid of a tool, a part that is removed in accordance with
the instructions for use, even if a tool is needed for removal, or a part that does not fulfil the
test of 22.11
NOTE 1 If for installation purposes a part has to be removed, this part is not considered to be detachable even if
the instructions state that it is to be removed.
NOTE 2 Components that can be removed without the aid of a tool are considered to be detachable parts.
NOTE 3 A part that can be opened is considered to be a part that can be removed.
现有一部件,不借助工具就能取下,但可以通过22.11试验。该部件算可拆卸部件还是不可拆卸部件?
发表于 2011-11-27 13:35:53 | 只看该作者
注2:不借助于工具就能取下的元件,认为是可拆卸部件。照楼主说的是可拆卸部件.
GMT+8, 2026-10-18 03:04 , Processed in 0.027393 second(s), 18 queries , Gzip On.
