查看: 570|回复: 0
Which standard should be apply for mediun voltage converter
发表于 2011-11-25 22:12:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Now my company wanna have a UL certification for our medium voltage converter, brief introduction as below:
Power cell: input:690V/3 phases, output voltage and frequency can be adjusted.
System:6 power cells in series, and then the total output voltage can be very high.
After checking the UL standards, I think UL508C and UL347A will be used, but UL508C only applies to 1500V and below, UL347A is for more than 1500V. From my side, I think UL347A is a supplement for UL508C, so I feel our products should follow UL508C first for the power cell, then for system, we can use UL347A....
Am I right, or if my friends have other advise or instruction, pls kindly instruct me.
Thanks!
GMT+8, 2026-11-17 14:33 , Processed in 0.052309 second(s), 18 queries , Gzip On.
