查看: 431|回复: 3
65结构检查疑问(新手提问)
发表于 2011-11-23 22:35:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1, 污染等级怎么定义?(拿到一个样品,这个怎么定义呢?)
2, 翘板式和推推式开关不属于全极开关吗?
3, 防火外壳的定义.(金属外壳算不算防火外壳,如果是塑料的,那怎么定义)
麻烦各位看看,谢谢!!!
 楼主| 发表于 2011-11-23 22:36:06 | 只看该作者
怎么没人回答, 顶下.
发表于 2011-11-23 22:36:27 | 只看该作者
60950-1中:
Pollution degree 1 applies where there is no pollution or only dry, non-conductive pollution. the pollution has no influence.normally ,this is achieved by having components and subasssembilies adequately enclosed by enveloping or hermetic sealing so as to exclude dust and moistrue
Pollution degree 2 applies where there is only non-conductive pollution that might temporatily become conductive due to occasional condensation. it is generally appropriate for equipment covered by the scope of this standard
Pollution degree 3 applies where a local environment within the equipment is subject to conductive pollution, or to dry non-conductive pollution that could become conductive due to expected condensation.
发表于 2011-11-23 22:36:37 | 只看该作者
金属肯定是防火外壳.一般产品金属外壳的温度肯定不会超过其熔点.防火外壳主要是针对塑料外壳而言.一般常见塑料外壳的防火可分为V-0,V-1,V-2,HB等级,V-0防火等级最好,HB等级最弱.如果是安全电路的产品外挂LPS电源的话,选用HB等级的就可以了.但是电源通常就要选用V-0等级了.
PCB板一般选用V-0等级.
GMT+8, 2026-11-18 16:36 , Processed in 0.034189 second(s), 18 queries , Gzip On.
