查看: 494|回复: 1
FCC认证分类
发表于 2011-11-20 21:28:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天做了自动柜员机的FCC认证试验,做的时候是按9254标准做的。
结果出来后我去问是否能拿到证,试验人员说不确定是属于A类还是B类,又说以前都是按B类做的。
我看了一下,Part 15上是这么规定的:
Class A digital device-A digital device that is marketed for use in a commercial, industrial or
business environment, exclusive of a device which is marketed for use by the general public or is
intended to be used in the home.
Class B digital device.-A digital device that is marketed for use in a residential environment
notwithstanding use in commercial, business and industrial environments. Examples of such devices include, but are not limited to, personal computers, calculators, and similar electronic devices that are marketed for use by the general public. Note: The responsible party may also qualify a device intended to be marketed in a commercial, business or industrial environment as a Class B device, and in fact is encouraged to do so, provided the device complies with the technical specifications for a Class B digital device. In the event that a particular type of device has been found to repeatedly cause harmful interference to radio communications, the Commission may classify such a digital device as a Class B digital device, regardless of its intended use.
除此之外,在Section 15.3 Definitions 还有很多其它类别,究竟ATM应该按照哪个类别来做?各自的参数有何差异?规定中的各种环境具体定义是如何的?
发表于 2011-11-20 22:05:11 | 只看该作者
支持。。。。
GMT+8, 2026-11-20 12:20 , Processed in 0.026291 second(s), 18 queries , Gzip On.
