查看: 499|回复: 0
标准里关于防火外壳不理解的point
发表于 2011-11-19 22:29:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在60950的4.7.2.2 Parts not requiring a fire enclosure中有写
components in SECONDARY CIRCUITS:supplied by internal or external power sources that are limited to a maximum of 15 VA
(see 1.4.11) under normal operating conditions and after a single fault in the equipment
(see 1.4.14) and mounted on HB75 CLASS MATERIA,L if the thinnest significant thickness
of this material is < 3 mm, or HB40 CLASS MATERIAL, if the thinnest significant thickness of
this material is ≥ 3 mm;
这里说如果PCB板的厚度<3mm,它至少要用HB75 CLASS MATERIA,如果PCB板的厚度>3mm,它至少要用HB40CLASS MATERIA,75的等级不是比40的要低吗?板子越薄应该用较高的防火等级才是啊,怎么是相反的呢?
哪位高手能指点迷津啊?非常感谢。
GMT+8, 2026-11-30 17:42 , Processed in 0.034135 second(s), 18 queries , Gzip On.
