查看: 480|回复: 1
关于UL 1054标准
发表于 2011-11-19 20:33:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
UL 1054 标准要求
每年做一次带功率因数的大电流实验。但是这个电流的标准怎么确定?
发表于 2011-11-19 20:34:04 | 只看该作者
Switch Testing:
6.2 Overload: CSA C22.2 No. 55-M1986 ( Reaffirmed 2003).
6.2.1.2
A switch shall be operated manually or mechanically by means of its actuating member for 50 cycles at the rate of 6—10 cycles/minute, making and breaking the required test current, except that the rate of speed of operation may be greater than 10 cycles/rn in
with the agreement of those concerned.
6.2.2.2
A switch rated in horsepower and intended for use only on ac circuits shall be capable of withstanding an overload test with an ac inductive load such that the switch will make and break a current equal to six times the full-load current of a motor having the horsepower rating in question, and having a power factor of 0.40—0.50 unless the manufacturer prefers that a lower power factor be used. Compliance of a switch with the foregoing requirements shall be determined under the test conditions described in Clauses 6.2.1.2 and 6.2.1.3 and 6.2.1.5 to 6.2.1.8 inclusive.
GMT+8, 2026-11-30 17:45 , Processed in 0.025277 second(s), 19 queries , Gzip On.
