查看: 440|回复: 1
ul1446中的一句看不懂,谁能帮我
发表于 2011-11-16 22:13:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近在翻译UL1446标准
以下这个看不太懂,是关于电机的,有谁能帮我下吗
4.10 MOTORETTE – A unit constructed in accordance with the specifications in IEEE No. 117,
Standard Test Procedure for Evaluation of Systems of Insulating Materials for Random-Wound AC
Electrical Machinery, except that:
a) The slot assembly, comprised of both inner and outer slot plates, shall be constructed of
stainless steel; and
Exception: When stainless steel is not able to be used due to difficulty in material adhesion, such
as an epoxy coating, or similar problem, cold rolled steel is able to be used.
主要是红字部分看不太明白
可能是我对电机的情况不是太了解吧,有高手吗
发表于 2011-11-16 22:13:52 | 只看该作者
楼主,不要发重复的帖子.你在新手区也发了这个帖子了.
http://www./read.php?tid-26105.html
GMT+8, 2026-11-30 18:18 , Processed in 0.026331 second(s), 18 queries , Gzip On.
