查看: 426|回复: 1
ULmyhome怎么注册?
发表于 2011-11-12 18:56:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
UL的myhome怎么注册呢?为什么我每次去注册的时候都注册不了呢?请教各位了?
发表于 2011-11-12 18:56:41 | 只看该作者
You can
1. ask UL factory auditors, normally, they have a document which can instruct the manufacturer how to apply for the UL myhome, originally was called UL CDA;
2. contact UL suzhou office 0512-68086400, then there will be a selection about how to apply for the UL myhome.
and I remember, first you must register an account at the UL website:www.ul.com, then there will be a procedure which need the UL's approval, after approved by UL, then the UL myhome will be effective for you to check your factory's FUS procedures and the inspection report&VN...
GMT+8, 2026-11-30 18:18 , Processed in 0.028586 second(s), 18 queries , Gzip On.
